Beckhoff CX1020
Tx for answer.
I Found answer maybe here?
Control software:
TwinCAT PLC run-time,
NC PTP run-time,
NC I run-time
but here is nothing about TwinCat2??
but if i looking for example CX5010 Control software for this PLC is
TwinCAT 2 runtime
TwinCAT 3 runtime (XAR)
i'm new in Beckhoff so is not easy understand
They only list TC2, not 3, as an option to be preinstalled on the CX1020. I'm not sure what determines which versions are actually compatible, though. The CX5010 is a newer controller and can be ordered with either version of runtime.
Hi Can't get Connected Between Beckhoff CX1020 and PC TWINCAT2 tried 3 laptops and differents cables . i can see ip address on WINCE this is...
6,604
Dear Sirs, We have fourteen machines and each one has a Beckhoff CX1020-0111 PLC in it. There is also a CX1100-0004 Power supply in each machine...
3,137
Hello, I have a problem, when i want to connect to the beckhoff PLC ( CX1020 ). My problem: I'm using a crass cable and i bring the IP...
1,859
1,638
Hi everyone, I've got the following task - build a project for controlling digital outputs, and reading from digital inputs using a Beckhoff...
2,420
