Hi All
we have a machine with a Beckhoff PC Controlled plc system.
We are having endless problems with the stability of the system and cannot find out what is going on. Hopefully someone with more beckhoff knowledge will be able to assist.
Basically what happens is that the machine stops working. When we look at the system control we see errors of modules changing between int and op. ant the topology will show a red dot by the same module. Sometimes restarting the machine a few times and the problem goes away. Sometimes we end up replacing the modules and this corrects the problem. What is a concern is the rate at which we are changing the modules almost weekly.
We got called to the machine yesterday and the machine showed 11 faults. Please see attached picture. Can someone please give some insight into what is going on with this machine.
