[Beckhoff - TwinCAT3] How to get used system resources ?
AndreLuis
Dec 2018
RJ
Hello,
I would like to know if anyone can tell which Library under Twincat3 (VisualStudio IDE) is assigned to get runtime information about free RAM amount/percentage of the PLC is available as well as the CPU core percentage processing. I searched on the manufacturer's website but did not find anything.
Thanks in advance.
What system are you using? Embedded PC or Industrial PC? You should start with this
https://download.beckhoff.com/download/document/ipc/industrial-pc/ipc_diagnostics_en.pdf
if you are using IPC. If that is not the case, I don't know what options you have for Embedded system.
Bear in mind that not all parameters that are available for fetching through function blocks can be read, it depends on motherboard type that particular IPC is using.
I have used these FB's successfully for reading out IPC CPU usage, if you need further help - feel free to ask.
Hey Everyone, hope everyone is safe and healthy. So I got my hands on the following hardware. I have no experience in programing in ST and...
6,074
I did a Beckhoff TwinCAT3 motion training course a couple of months ago. To be honest, it was a little tough going as it was my first sight of...
3,043
I'm new to TwinCAT3 and I've been searching for a tutorial on object-oriented programming. I've seen this link on Beckhoff's Infosys site but was...
2,813
TwinCat3 Beckhoff "Add route to remote system failed ADS Error 1804 (0x70C)" Hi everyone, I have a problem connecting with a Beckhoff CX5120...
40,575
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
75
