Hi all,
I came across a problem today while downloading a hmi to a Beijer E1101 firmware version V1.5 using E-designer 7.31.
Basically it wouldn't load telling me I did not have the correct firmware version for the screen. I had only up to 1.3x and the screen was 1.5x.
So it asked me if I should abort, tried this a couple of times but it didn't load.
Doing this over ethernet direct to the screen btw!
Anyhu this is all being done on a virtual xp machine mounted onto my new windows 7 machine.
Solution got an actual xp machine with the exact same software and version as mentioned above loaded fine!
I have looked all over for firmware version 1.5x for this screen and can't find it.....anyone know what the problem is, or where I can get the upgrade?
Also does anyone know when Mitsubishi will start to support windows 7?
