Information Designer Beijer question
alplus
Nov 2018
mtl
it's the first time i use this software... i would like add IO but the data type is empty...
What is the step that i forgot..
Thank you
Start the software.
Select New and select the HMI and the PLC.
Go to Help, Controller Help to find how to access memory in the PLC.
View, switch on Project Explorer.
Double click on Main.
Go to View / Toolbars and make sure that Objects is ticked.
Click on an object and then click on the screen and an a properties box for that object appears. Try Analog Numeric.
In the Analog Signal box type the PLC address, so for a Siemens S71200 I might type DB1.DBW16. That is the quick and dirty way.
If I wanted to select from a list of PLC memory locations I would go to View Name List and enter all the PLC memory locations I needed, or some PLCs allow you to Export and then Import, so that the list is automatically filled.
I'm working on an HMI running on a Beijer panel, and I'm trying to test out the project with the simulator in Information Designer. Does anyone...
3,659
Can someone give me a rough estimate on how much the Beijer Information Designer software costs.
2,734
Sir, I required Beijer Information designer software. Any one can help? Regards Harshad
5,449
Rockwell in their wisdom have made a mess of the Panelview Plus 7 operator interface terminals with all the different series hardware revisions...
332
Hello Everyone, I am setting up an Information message in FactoryTalkView ME. I'm just using the default information display. I want to make it...
852
