PanelViewPlus Information Setup
jamesgsummers
Feb 2019
Kansas City MO
18
Hello Everyone,
I am setting up an Information message in FactoryTalkView ME. I'm just using the default information display. I want to make it so that the Ack button and Close button do the same things or I guess I could just delete the Ack button. Either way the first thing I want is for the buttons to unlatch an OTL in my PLC. Then I want the Ack button to close the display. Obviously if I delete the Ack button this part won't matter but I would like to know if I could make the Ack button close the display just for fun. I know I could just make new buttons but that wouldn't be as much fun. Anybody got any suggestions? Thanks.
I am not the most experienced with the Painelview Plus, but I believe if you want multiple functions to be tied to a single button, you will need to look at using a "Macro" button object. It's not under "Push buttons" in the Objects menu, but under Advanced. The Macro needs to be created separately (look under the Log and Control category of the project explorer) and then assigned to the button action.
Hello Everyone,
tie it all to a tag in the program and set the acknowledge and close display to the same tag. should be under the trigger settings area for alarms, and global connections
I believe a Close Display button can write a single value to a tag on press in addition to closing the display it is on.
I ended up just deleting the Ack and Close buttons and adding an interlocked push button that I labeled ack. The bit that displays the message is on an OTL in the PLC and connected to the interlocking push button. When the conditions sets the OTL the message is displayed. When you hit the interlocked push button the OTL is unlatched and the message pop up closes on it's own. I don't think this would work if you had multiple info messages but this is the only one I'm using in this process so it works. I was over thinking it.
Hello to the community, I am new to Rockwell and I have a small problem with a PvP1000(2711P). Some buttons in the same screen are not...
2,349
Hello, I have a PV+ 1000 that I am unable to access the config screen on. All I want to do is upload the .mer that is currently running. I tried...
21
4,957
If you were to take a Panelview Plus, mount that in an enclosure that is purged by a purge unit that takes the environment from Class 1 Division 1...
5,656
So im working on a little something i was hoping to get some advice on. I have a PanelviewPlus 7 that will be using the MECSVLog ActiveX on to...
1,247
Hi all, I have a little problem with time displayed in trends. If i set a time in HMI, a time on X-axis in trends is shown as HMItime + 1 and i...
1,398
