Bekum Blowmolder PLC Code Compatibility
DigitalGuy
Jun 2012
California
Hi all,
As a startup, we coupled a long time blow molding professional and a digital design engineer to produce rock solid PLC control logic for a Bekum h-111 (h111) blow molding machine. We are now trying to compile a list of Bekum products which would be compatible with our PLC design. If any of you can recall Bekum (or other brand name) models that are compatible with the Bekum h111 we would like to hear from you. The code is designed for a single head/double carriage machine, but it may be possible to adapt it to other configurations. Once we have identified matching model numbers we will be looking for someone with a dead machine to do a test install of our newly developed control panel. Any advice would be appreciated- thanks.
I have a (potential) customer who has a Bekum H-151 blow molding machine and they would like to update the controls. This machine is about 1988...
8,114
188
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
186
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
40
250
