bitswaps in a byte SCL
userxyz
May 2002
any
2,768
Anyone know how to write this in SCL:
MB10
M10.0 = M10.7
M10.1 = M10.6
M10.2 = M10.5
M10.3 = M10.4
M10.4 = M10.3
M10.5 = M10.2
M10.6 = M10.1
M10.7 = M10.0
Mirror the bits in the byte.
How about this (untested):
Code:
FUNCTION_BLOCK FB200
VAR
byStore: BYTE;
Store AT byStore:ARRAY[1..8] OF BOOL;
END_VAR
BEGIN
byStore:=MB10;
M10.0:=Store[8];
M10.1:=Store[7];
M10.2:=Store[6];
M10.3:=Store[6];
M10.4:=Store[4];
M10.5:=Store[3];
M10.6:=Store[2];
M10.7:=Store[1];
END_FUNCTION_BLOCK
Hi
Can you make my code better, it works, but is giant:
Code:
[font=Arial][size=2]
VAR_INPUT
HW_OFFSET: INT;
HEIGHT_OFFSET: INT;
END_VAR
VAR
FIRST_BEAM: BYTE;
LAST_BEAM: BYTE;
STATUS: BYTE;
BEAM_BYTES: ARRAY [1..12] OF BYTE;
BEAM_BITS AT BEAM_BYTES: ARRAY [1..96] OF BOOL;
SWAPPED_BITS: ARRAY [1..96] OF BOOL;
HEIGHT: DINT;
OFFSET: DINT;
i: INT;
RESULT_0_255: DINT;
FIRST_BYTE: INT;
LAST_BYTE: INT;
END_VAR
VAR_OUTPUT
BOT: BYTE;
ACT_HEIGHT: INT;
END_VAR
BEGIN
FIRST_BEAM:= PIB[HW_OFFSET];
LAST_BEAM:= PIB[HW_OFFSET + 1];
STATUS:= PIB[HW_OFFSET + 2];
FOR i := 1 TO 12 DO
BEAM_BYTES[i]:= PIB[HW_OFFSET + 2 + i];
END_FOR;
HEIGHT:= ((BYTE_TO_DINT(LAST_BEAM)) * 1780) / 90;
ACT_HEIGHT:= (DINT_TO_INT(HEIGHT));
OFFSET:= (INT_TO_DINT(HEIGHT_OFFSET));
RESULT_0_255 := (255 * (HEIGHT - OFFSET)) / (1780 - OFFSET);
BOT:= (DINT_TO_BYTE(RESULT_0_255));
FIRST_BYTE:= (BYTE_TO_INT(FIRST_BEAM) - 1) / 8;
LAST_BYTE:= (BYTE_TO_INT(LAST_BEAM) -1) / 8;
IF BEAM_BITS[1]= TRUE THEN
SWAPPED_BITS[8]:=TRUE;
ELSE
SWAPPED_BITS[8]:=FALSE;
END_IF;
IF BEAM_BITS[2]= TRUE THEN
SWAPPED_BITS[7]:=TRUE;
ELSE
SWAPPED_BITS[7]:=FALSE;
END_IF;
IF BEAM_BITS[3]= TRUE THEN
SWAPPED_BITS[6]:=TRUE;
ELSE
SWAPPED_BITS[6]:=FALSE;
END_IF;
IF BEAM_BITS[4]= TRUE THEN
SWAPPED_BITS[5]:=TRUE;
ELSE
SWAPPED_BITS[5]:=FALSE;
END_IF;
IF BEAM_BITS[5]= TRUE THEN
SWAPPED_BITS[4]:=TRUE;
ELSE
SWAPPED_BITS[4]:=FALSE;
END_IF;
IF BEAM_BITS[6]= TRUE THEN
SWAPPED_BITS[3]:=TRUE;
ELSE
SWAPPED_BITS[3]:=FALSE;
END_IF;
IF BEAM_BITS[7]= TRUE THEN
SWAPPED_BITS[2]:=TRUE;
ELSE
SWAPPED_BITS[2]:=FALSE;
END_IF;
IF BEAM_BITS[8]= TRUE THEN
SWAPPED_BITS[1]:=TRUE;
ELSE
SWAPPED_BITS[1]:=FALSE;
END_IF;
FOR i:= 1 TO 12 DO
IF BEAM_BITS[(i * 8) + 1]= TRUE THEN
SWAPPED_BITS[(i * 8) + 8]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 8]:=FALSE;
END_IF;
IF BEAM_BITS[(i * 8) + 2]= TRUE THEN
SWAPPED_BITS[(i * 8) + 7]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 7]:=FALSE;
END_IF;
IF BEAM_BITS[(i * 8) + 3]= TRUE THEN
SWAPPED_BITS[(i * 8) + 6]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 6]:=FALSE;
END_IF;
IF BEAM_BITS[(i * 8) + 4]= TRUE THEN
SWAPPED_BITS[(i * 8) + 5]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 5]:=FALSE;
END_IF;
IF BEAM_BITS[(i * 8) + 5]= TRUE THEN
SWAPPED_BITS[(i * 8) + 4]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 4]:=FALSE;
END_IF;
IF BEAM_BITS[(i * 8) + 6]= TRUE THEN
SWAPPED_BITS[(i * 8) + 3]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 3]:=FALSE;
END_IF;
IF BEAM_BITS[(i * 8) + 7]= TRUE THEN
SWAPPED_BITS[(i * 8) + 2]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 2]:=FALSE;
END_IF;
IF BEAM_BITS[(i * 8) + 8]= TRUE THEN
SWAPPED_BITS[(i * 8) + 1]:=TRUE;
ELSE
SWAPPED_BITS[(i * 8) + 1]:=FALSE;
END_IF;
END_FOR;
END_FUNCTION_BLOCK
[/size][/font][font=Arial][size=2]FUNCTION_BLOCK FB200
VAR_INPUT
HW_OFFSET: INT;
HEIGHT_OFFSET: INT;
END_VAR
VAR
FIRST_BEAM: BYTE;
LAST_BEAM: BYTE;
STATUS: BYTE;
HEIGHT: DINT;
OFFSET: DINT;
i: INT;
RESULT_0_255: DINT;
FIRST_BYTE: INT;
LAST_BYTE: INT;
END_VAR
VAR_OUTPUT
BOT: BYTE;
ACT_HEIGHT: INT;
END_VAR
BEGIN
FOR i := 1 TO 12 DO
END_FOR;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
FOR i:= 1 TO 12 DO
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
ELSE
END_IF;
END_FOR;
END_FUNCTION_BLOCK
[/size][/font]
Code:
VAR
byStore: BYTE;
END_VAR
BEGIN
byStore:=MB10;
M10.0:=Store[8];
M10.1:=Store[7];
M10.2:=Store[6];
M10.3:=Store[6];
M10.4:=Store[4];
M10.5:=Store[3];
M10.6:=Store[2];
M10.7:=Store[1];
END_FUNCTION_BLOCK
Our system utilises INPUT_BYTE to capture NMEA0183 ASCII stream which sends data to the NOM multiple times a second. The NOM module can either be...
389
Hello everyone, friends. I need help with something. I want to read and change Bit and Byte numbers via HMI. I found a code snippet for this as...
18
3,038
Hello everyone :) I just want to start with learning PLC programming, so I need advice. I have SIMATIC S7-1200, CPU with integrated memory...
934
I have a C-More HMI that changes my PLC String from "Machine Status" to "aMhcni etStasu" . There is an option with other objects that have string...
3,480
Hello I have got a problem with positive edge from "system clock memory byte" in Tia Portal. I would like to change byte"system clock memory"...
27
3,611
