Blue Screen: RSLinx - AB_KT-1 DH+
donl517
Dec 2005
Michigan
127
I have this driver loaded in RSlinx and every time I try to Stop or Delete it I get the Blue Screen of Death. Is there an update or a workaround to unload this driver? (Revision: 2.43.01.23 (CPR6))
Thanks,
Don
You are using windows XP probably, and you are using the PCCard KTX card?
Simple.. You installed it improperly, NOT selecting the proper card when you configured it in Linx.
Boot to Safe Mode
Run Regedit
Go to the key: HKEY_LOCAL_MACHINE\SOFTWARE\Rockwell Software\RSLinx\Drivers
Delete any and all folders that list a 'KT', as in "AB_KTLIKE"
Reboot.
When you first configure the card, MAKE ABSOLUTLY SURE YOU SELECT THE RIGHT CARD FROM THE DROP-DOWN BOX!
Thanks Rdrast,
I had actually been trying to connect to a PLC at a customers site, to no avail, I tried several drivers and when I got to this one; bingo, Crash!
Thanks Again,
Don
I too had the same problem. Two new PCs and two new 1784-PKTX cards for DH+. BSOD. Turns out I picked the KTX driver not the PKTX driver. Simple fix, to what appeared to be a major problem.
Whew!
Marc
Had my first unrecoverable blue screen on Thursday. I got the following error “driver_verifier_DMA_violation” I’ve tried just about everything...
4,501
Hello all, recently bought a Keyspan Tripp Light 19HS USB to Serial adapter, due to the recommendations of a few people here on the forums. Its...
4,249
FactoryTalk machine edition downloads my .mer as a blue screen. It was downloading and working till I created two more screens, and I guess I did...
4,249
Hello everybody! I'm new, so I apologies if I'll make some mistakes. ok So, let's begin. I have an IBM A31 laptop with 1.7GHz processor and 256MB...
9,023
I was so happy. I finally invested in a new laptop. I even found one with a seriel port. I got a new Dell latitude D820. It has dual core intel...
6,712
