Hello,
Has somebody ever tried to bootstrap a Siemens panel?
I had problems with updating OS on a Siemens OP277 panel.
After that I could not get the connection working because the panel would not boot up.
It only says bootloader with its version, and a MAC adress.
The manual said I should try to bootstrap using the serial port. I did, but got baud rate detection error.
Have tried every different baud rate, both COM1 and COM3 ports.
COM3 is the only one that is trying to read information from the panel, but while it is doing this it pops up a baud rate detection error message.
Anybody faced similar problem??
brg
Andreas
brg
Andreas
