Bosch Rexroth Indralogic
bsiebrits
Jan 2019
Brackenfell
Good Day
I trust you are well,
I am struggling to find someone that is familiar with the software "bosch Rexroth Indralogic Engeneering" I am getting an error every time I try and go live.
The error is as follows;
Invalid global variables, unable to logon
I then click on okay and I get told the SSI module is invalid or fault but when I go and look in the directory it does appear to be there.
If anyone could please assist or point me in the right direction it would be much appreciated.
Thanks a million
Brad
Good Day
Thanks a million
Brad
Hi Brad
I have experience with Rexroth Hardware..but unfortunatley not the indralogic stuff, hopefully someone else will come to support you. However; if you have not heard anything in the next few days; I will boot the software up and take a look for you.
Regards
Daniel
Hi Brad
Regards
Daniel
Thanks Daniel, Much appreciated.
Hello . I have some kind of problem with loading program into CLM 1.4. I have working controler which has first symptoms of coming failure...
1,271
Hi guys, My name is Kevin, and I'm doing internship right now. I need to make an universal denester, filler and lidder. Right now I'm designing...
4,344
Dear Sirs, in my current application, I am using a Bosch Rexroth L20 PLC communicating with Hightec PWS-6A00T-N HMI, but in the configuration of...
4,137
Hi All Bosch-Rexroth phases out DPQ and DPC cards. Russian office of the company advised to consider HACD-3 or HCN100 cards to control 2 axes...
2,045
Hello, We are using a VIPA TP605 to communicate with an S7-300 and now also want to add Bosch Rexroth MLC and MLD-S. Both BR devices use Codesys...
3,446
