Both PLC in redundant system becomes active
smartatuls
May 2013
India
30
I have CRU320 CPU with two RMX128 modules on Primary and Secondary rack works as a redundant system.
Some how if the fiber link between two RMX128 of Primary and secondary is not working which makes both PLC as active and creates confusion :oops: to machine for its operation.
Can anyone help me on this issue?
I'm using a Automationdirect CLick PLC (c0-02dd2-d). It has 2 RJ12 ports and 1 designated RS485 (we will call this port 3) port. My thought...
3,199
Hello! I have to build a communication between S7-400 series PLC and several S7-300 series PLCs. The problem is, that the same tag (for example...
1,525
Dear experts, i have a CT 600/5A and analog Amps meter 0-600A @2.5Class, 1)now i want to measure the same current to changing analog meter to...
2,425
Can any body tell me how to connect both analog & Digital I/P & O/P's modules through PLC. If you have any diagram plz attach it... Actually i...
2,930
The differential pressure transmitter output(4 to 20 mA) is connected with PLC. Now i want to connect with recorder too in series with PLC...
2,780
