jjwitty
I have a machine that fills 12 bottles of oil. The bottles are normally filled using mass meters which are set by operators from HMI. Lately we have lost 3 meters and the machine has been down. This has cost the company thousands. To get them up and running, I have programmed the valves connected to the bad meters to open/close using TON. During testing this has worked very well. I was able to match the fill levels of good valves with the timers on the bad valves. I have programmed the HMI so the operators can adjust the times on the timers also. I have one problem, sometimes the filler is sped up and down. This would cause operators to have to adjust timers. To combat this, I am thinking of ways to time the good valves and move that accumulated value into the preset of the bad valves. To me, that would remove all operator involvement in the filling process except starting the machine. What I’m concerned about is scan time and how that may effect the time of the bad valve. Even 250ms could cause the bottles to overfill. What does everyone think ?
