br-automation panel slave controller
sshijuthomass
Jun 2010
UAE
Please help me, Where can i download the software for connecting pc and br-automation panelware 4C2210-01-510, thanking you in anticipation
Hello,
according to data sheet it needs to be progammed with PG2000(PL2000).
I personally could provide you PG2000, but I do not have PL2000.
Please see also this link in case you dont know already,
there is some chapters about panelware and also documentation about cable and so on....
http://www.br-automation.com/cps/rde/xchg/br-productcatalogue/hs.xsl/services_66491_ENG_HTML.htm
In the end I think you should write an Email to B&R support to provide you a download link for PG.2000 as well as PL.2000 (I guess it is this what you need to change the display, PG.2000 for the PLC control changing).
hope it helps,
br
bb
br-automation
thank you very much ,for the help pl also let me know where can i get the dispaly board for br-automation 2x40VFT (4D2024.00-090) or equivalent in middle east.
regards
Shiju
Hello,
hope it helps,
br
bb
I'm recreating a program for an existing machine. I'm new to B&R. When I install an older version of Automation Studio (~4.9), I can create a...
657
Have a power panel 400 from BnR automation and the display screen will not power up. The panel displays a green LED that its recieving power, but...
3,239
I am trying to decide which HMI to use on a machine. I need a 7 to 10 inch touch panel for a small machine, and I can not decide which HMI would...
36
25,037
I Need Some Help On This Touch Panel. I'm Not Sure Where To Start But Here Is My Problem. On The Screen We Have Key Pad With Numeric Numbers 1-9...
3,631
Has anyone tried these out? I talked to a tech support guy at EZAutomation today and he told me these panels with the "Universal Ethernet" option...
4,279
