Breaking up .DATA into two arrarys
garlantm
Aug 2016
Michigan
28
Hello All,
First of all I am using an AB Logix 5571 revision 30.
I am trying to use a FBC to tell me which slave is unplugged in order. The original Way that i did this was to move the .LEN from a string to a FBC where I could compare it in 3 arrays(please see the picture below). The problem I am now having is that what I need to compare is 64 bits and not 32 bits like the original program. To do this I had to move it form the .LEN of the string to the actual .DATA this gives me plenty of space but I cannot figure out how to divide it in half (use two FBC commands instead of 1).
Please note image 1 is how I would like to devide the .Data
image 2 is how this was done with the .LEN of a string
image 3 is how I would like to do it now. But it is not working
Thank you
Hello,
I do not really know how to make the picture bigger, But I will export the routine if that helps? If you cannot open it then please let me know and I will try to resize my pictures somehow.
Thank you,
I think your problem might be the COP instruction. The length in the COP instruction is based of the size of the destination elements. You are copying 4 dints worth of data into your dint array from the array of 4 sints. This will be smashing the other DINTs of destination array that you are trying to use as parameters in the FBC command.
Change the Length to 1. That will copy 4 bytes of data into the DINT.
Thank you Geoff, I ended up using a little different technique to get the data that worked. So I found out that when it was copying with a length of 2 it would just overflow into the next set of the array . Since with AS-I it is always 32 slaves it worked out perfectly(1 slave per bit of the DINT) . So for A slaves I am looking at the first array and for the B slaves I look at the 2nd array. These then are moved to the FBC for comparison when a problem is detected.
Thanks again,
Trent
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,864
I know tabview is not a PLC but I also know that some of you use LabView for a HMI and data acquisition. We have at a !@#$% if a time with...
4,331
I was listening to the radio today and a discussion about Simulation Hypothesis came on and it was quite intriguing and actually entertaining. I...
2,055
Since I had to relocate, I've been working in new construction as an electrician, however my boss is definitely open to letting me take on...
2,969
Hi Everyone, I need some method/tool/utility/software for breaking the password in Siemens S7-400 CPU. password protection level is 3(write/read)...
7,041
