Bubble sort but, on a whole table
Hmm
The errors are located in the FOR NEXT loops,
3 errors in the first FOR NEXT and 3 errors in the second FOR NEXT loop...
A little things corrected, now I have 6 errors instead of 14
Here is the code:
IF SORTO_FLANK THEN
FOR i:= 0 TO 500
IF "ORDER_NUMMER".VARi= 0 THEN
"ORDER_NUMMER".VARi:= 50000;
END_IF;
END_FOR;
REPEAT
SWAP:= FALSE;
FOR index:= 500 TO 1 BY -1 DO
IF "ORDER_NUMMER".VARi[i - 1] > "ORDER_NUMMER".VARi THEN
aux1:= "ORDER_NUMMER".VARi;
"ORDER_NUMMER".VARi:= "ORDER_NUMMER".VARi[i - 1];
"ORDER_NUMMER".VARi[i - 1]:= aux1;
END_IF;
END_FOR;
UNTIL NOT swap
END_REPEAT;
FOR i:= 0 TO 500
IF "ORDER_NUMMER".VARi= 50000 THEN
"ORDER_NUMMER".VARi:= 0;
END_IF;
END_FOR;
END_IF;
I Forgot Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Do Do Do Do Do
Last Code
SORTO FLANK IS AN EDGE BIT; 1 cycle high..
Code:
 IF SORTO_FLANK THEN
	FOR i:= 0 TO 500 DO
		IF "ORDER_NUMMER".VARi[i]= 0 THEN
		 "ORDER_NUMMER".VARi[i]:= 50000;
		END_IF;
	END_FOR;
REPEAT
swap:= FALSE;
		IF "ORDER_NUMMER".VARi[i - 1] > "ORDER_NUMMER".VARi[i] THEN
		aux1:= "ORDER_NUMMER".VARi[i];
		"ORDER_NUMMER".VARi[i]:= "ORDER_NUMMER".VARi[i - 1];
		swap:= TRUE;
		END_IF;
	END_FOR;
UNTIL NOT swap
END_REPEAT;
	FOR i:= 0 TO 500 DO
		IF "ORDER_NUMMER".VARi[i]= 50000 THEN
		 "ORDER_NUMMER".VARi[i]:= 0;
		END_IF;
	END_FOR;
END_IF;
THIS IS MY LAST CODE;;; STILL NO DIFFERENCE? IT WRITES 50000 IN THE EMPTY PLACES AND DOES NOT A SORTATION ?
Found It
Code:
IF SORTO_FLANK THEN
	FOR i:= 0 TO 500 DO
		END_IF;
	END_FOR;
 REPEAT
 swap:= FALSE;
		IF "ORDER_NUMMER".VARi[index - 1] > "ORDER_NUMMER".VARi[index] THEN
		aux1:= "ORDER_NUMMER".VARi[index];
		"ORDER_NUMMER".VARi[index]:= "ORDER_NUMMER".VARi[index - 1];
		"ORDER_NUMMER".VARi[index - 1]:= aux1;
		swap:= TRUE;
		END_IF;
	END_FOR;
 UNTIL NOT swap
 END_REPEAT;
	FOR i:= 0 TO 500 DO
		END_IF;
	END_FOR;
END_IF;
I'm still sleeping, I found it i had to be index
Final Code For Whole Table
Code:
 IF SORTO_FLANK THEN
	FOR i:= 0 TO 500 DO
		END_IF;
	END_FOR;
 REPEAT
 swap:= FALSE;
		aux2:= "REGEL_NUMMER".VARi[index];
		"REGEL_NUMMER".VARi[index]:= "REGEL_NUMMER".VARi[index - 1];
		"REGEL_NUMMER".VARi[index - 1]:= aux2;
		aux3:= "LEVER_DATUM".VARi[index];
		"LEVER_DATUM".VARi[index]:= "LEVER_DATUM".VARi[index - 1];
		"LEVER_DATUM".VARi[index - 1]:= aux3;
		aux4:= "BUIS_TYPE".VARi[index];
		"BUIS_TYPE".VARi[index]:= "BUIS_TYPE".VARi[index - 1];
		"BUIS_TYPE".VARi[index - 1]:= aux4;
		aux5:= "GRONDSTOF_LENGTE".VARi[index];
		"GRONDSTOF_LENGTE".VARi[index]:= "GRONDSTOF_LENGTE".VARi[index - 1];
		"GRONDSTOF_LENGTE".VARi[index - 1]:= aux5;
		aux6:= "KLANT_NUMMER".VARi[index];
		"KLANT_NUMMER".VARi[index]:= "KLANT_NUMMER".VARi[index - 1];
		"KLANT_NUMMER".VARi[index - 1]:= aux6;
		aux7:= "ARTIKEL_NUMMER".VARi[index];
		"ARTIKEL_NUMMER".VARi[index]:= "ARTIKEL_NUMMER".VARi[index - 1];
		"ARTIKEL_NUMMER".VARi[index - 1]:= aux7;
		aux8:= "MATRIJS_STEMPEL_1".VARi[index];
		"MATRIJS_STEMPEL_1".VARi[index]:= "MATRIJS_STEMPEL_1".VARi[index - 1];
		"MATRIJS_STEMPEL_1".VARi[index - 1]:= aux8;
		aux9:= "MATRIJS_STEMPEL_2".VARi[index];
		"MATRIJS_STEMPEL_2".VARi[index]:= "MATRIJS_STEMPEL_2".VARi[index - 1];
		"MATRIJS_STEMPEL_2".VARi[index - 1]:= aux9;
		aux10:= "MATRIJS_GATEN".VARi[index];
		"MATRIJS_GATEN".VARi[index]:= "MATRIJS_GATEN".VARi[index - 1];
		"MATRIJS_GATEN".VARi[index - 1]:= aux10;
		aux11:= "BUIS_MATERIAAL".VARi[index];
		"BUIS_MATERIAAL".VARi[index]:= "BUIS_MATERIAAL".VARi[index - 1];
		"BUIS_MATERIAAL".VARi[index - 1]:= aux11;
		aux12:= "BUIS_DIAMETER".VARi[index];
		"BUIS_DIAMETER".VARi[index]:= "BUIS_DIAMETER".VARi[index - 1];
		"BUIS_DIAMETER".VARi[index - 1]:= aux12;
		aux13:= "BUIS_DIKTE".VARi[index];
		"BUIS_DIKTE".VARi[index]:= "BUIS_DIKTE".VARi[index - 1];
		"BUIS_DIKTE".VARi[index - 1]:= aux13;
		aux14:= "WENS_LENGTE".VARi[index];
		"WENS_LENGTE".VARi[index]:= "WENS_LENGTE".VARi[index - 1];
		"WENS_LENGTE".VARi[index - 1]:= aux14;
		aux15:= "WENS_HOEK_1".VARi[index];
		"WENS_HOEK_1".VARi[index]:= "WENS_HOEK_1".VARi[index - 1];
		"WENS_HOEK_1".VARi[index - 1]:= aux15;
		aux16:= "WENS_HOEK_2".VARi[index];
		"WENS_HOEK_2".VARi[index]:= "WENS_HOEK_2".VARi[index - 1];
		"WENS_HOEK_2".VARi[index - 1]:= aux16;
		aux17:= "WENS_AANTAL".VARi[index];
		"WENS_AANTAL".VARi[index]:= "WENS_AANTAL".VARi[index - 1];
		"WENS_AANTAL".VARi[index - 1]:= aux17;
		aux18:= "WENS_AANTAL_BUNDEL".VARi[index];
		"WENS_AANTAL_BUNDEL".VARi[index]:= "WENS_AANTAL_BUNDEL".VARi[index - 1];
		"WENS_AANTAL_BUNDEL".VARi[index - 1]:= aux18;
		swap:= TRUE;
		END_IF;
	END_FOR;
 UNTIL NOT swap
 END_REPEAT;
	FOR i:= 0 TO 500 DO
		END_IF;
	END_FOR;
END_IF;
works
Hello all, I was looking into different sorting techniques and actually found a bubble/insertion sort sample code file on Rockwell's site. Only...
20
5,286
Hello, I been trying to sort some values in the the Do-more PLC but still have some issues. I have 20 elements from the data view with random...
3,667
Hi, im creating compressor station project with S7-1200. Project requires that 4 compressors should work in cascade - that's already done, and...
11,623
Hi all, I need some help here please. I'm trying to understand the SCL programming example included in the SIEMENS SCL official documentation...
7,829
Good afternoon guys, I have a basic question on the bubble level in the picture attached. This is probably really easy, but I don't get it, haha...
3,369
