Bus Sytems In Hazardous Areas
Jim Davie
Mar 2003
Near Glasgow, Scotland
Can anyone give me some advice on running Profibus or DeviceNet through hazardous areas. Is it true to say that as long as the field equipment is rated for the area it operates in it's only necessary to barrier the bus cable as it leaves the safe area as you would do for every signal on multicores with traditionaly wired I/O. :)
Thanks In Advance
The answer to your question maybe different from country to country, but there are products that have a gateway to profi or devecinet and are intrinsically safe I/O networks, here's a link to one of them
InterlinkBT
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
55
91
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
128
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
244
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
182
