C-Net and lightning strike
curlyandshemp
Jul 2005
Toronto
1,903
Anyone else have this situation:
Severe thunderstorms pass through area, lightning hits the building , or nearby, and six 20-Comm-C adaptors on PowerFlex 70 VFDs all catch fire and burn up. 1794-ACN, 1756-CNB, PV1000 on same C-Net trunk line do not.
Ian
Lightning is unpredictable, and the damage does not always appear to be logical. The path of least resistance for lighting is not always apparent to humans.
Lightining myth: You are safer inside a building than outside.
Fact: More people are struck by lighting while inside a house. Houses have 1/8" fiberglass shingles, 3/4" roof decking, some insulation, and 5/8" of sheetrock. Those thin barriers offer absolutely no protection from a force that jumped though thin air for 5000 feet (or more).
two years ago lightning strike on my backyard killed cable internet modem, router and one of the ethernet switches 100 ft away.
But all computers connected to the router right next to it survived.
Why? I heard it is unpredictable and no common rules apply...
Controlnet trunkline is ungrounded system, so something in 20-comm may be weaker than in other devices. It's possible that other devices are partially damaged as well.
I guess strike force was much higher than device ratings.
163
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
113
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
90
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
143
