C7-626
TheVo
Guest
T
Hi
I have a C7-626. I want to change it but I do not have the source program. Could you help me how I do?
Hi TheVo,
I'll ask u first: Do u have the S7-Simatic manager to back up ur PLC part of program?Also do u have the Protool program to back up ur HMI part?
You need both of them, but for the PLC part if ur panel is equiped with a flash memeory, ur PLC part will mostly be stored there, so u only need to put ur current flash in the new unit & reboot. For the text part u need to get your Protool to download that one.
Cheers
Hagos
ok, you can load the program into the Pc, but you lost all network- and block discription. Before you make a change, you must understand the program. what means the Flag and makes this functionsblock.
good luck
Hi
Thank you for your help
I have STEP-7 and PROTOOL sofware. I were backup the program S7 for my C7, but PROTOOL software can't upload program from HMI to PC. Do you have any way to upload it. I try to use Prosave but it haven't support for C7-626.
I need to load to a C7-626 OP and wondered how to put it into serial transfer mode. I know that usually you can press a couple of keys during boot...
3,262
I
Hallo boys, Can I find anywere schematics and pin-out of OMRON serial cables CS1W-CN226 (CS1W-CN626) or description of CS1G PLC peripheral port...
9,148
