Cabinet Communication Ports
ilikbeer
Oct 2004
Defiance, Ohio
101
Anyone have any cool ideas for putting comm ports on the outside of cabinets.
I need a couple DB-9 connections and a Cat5.
Looking at the Allied 354-0004 Bulkhead connector, which is just for Cat5, but thought it would be nice if i could have all 3 in a nice box unit with a lid.
Thought I'd pick your brains and see what the pros use.
Thanks for taking the time to help.
Check out these guys:
http://www.graceport.com/commonports.cfm
They used to have a nice configurator on the site, but I can't find it now. Usually, I just tell my dealer what I need, and let him figure it all out.
They can pretty much put anything together, I usually have Power, Ethernet, Dual USB, and sometimes DB9's mounted. The external mounted interfaces have a lockable, clear lexan or polycarbonite lid by default.
Panel Interface Connectors, try automationdirect ZP-PSA-32-400 it has two DB9 and an RJ45, might work for you.
Phoenix Contact also has some stuff like that, though to be honest, it's a pain in the *** tracking some of these things down sometimes.
My company recently tried to track down some of these with a Dsub 9 pin to breakout (running DH+ through dsub) and a power recepticle. That combination is apparently a pain to find. One supplier ended up ordering 9 pin dsub female-female with a recepticle. We *****ed them out, because we could have gotten the same thing cheaper and faster from another supplier. We then ended up ordering that part form the other supplier, lol.
Hello to Everyone! I am looking for Ethernet/IP Distributed In-Cabinet IO Block options to talk to Compact Logix PLC (L36ER). I only need 3 DO's...
2,988
i have a customer who is pushing back on something i have not encountered before. the cabinet is a local control panel consisting of PL, PB, HMI...
4,533
Hi all, Hope this is not too off-topic, The question: Does anyone have an idea how much distance typically is available between the cable ducts...
2,110
Hello, I was going to mount the Xformer to the panel and still can, but it was brought up that we should just bolt it to the bottom inside of the...
3,127
Hello, I'm new to AutoCAD and had some questions. If I make a border at roughly 8"x11" or something like that... How do I insert something that...
3,337
