Cable pin out needed
Its not that easy... you also need a converter, as the 503 is a 485 protocol and you have to convert to rs232
Does your 503 have a serial also? that would be the cheapest route, if not you will need a PIC
Yes, SLC has another port but it is occupied by radio modem and I can’t disconnect it.
DE485 port is connected to DTAM panel and it can be disconnected at anytime. What are the other solutions for connecting? I thought it’s just cable problem !?!
geniusintraining what is "PIC" ?
Mickey has pointed to the UIC
I sell the PIC's on my site
You can use either one, I don't know a lot about the UIC's as I don't make or sell them but read the PDF's they look very nice
Depending what operating system you are running on your PC is dependent on if mine will work, mrplc.com also sells a PIC that is better then mine.. but it cost more, someday (soon I hope) I will be selling them
EDIT: Allen Bradley 1747-PIC http://www.plctrainer.net/PLCProgrammingCables.htm
I need a pinout for a GE cable 336A4929G1. Thanks
3,169
Dear friends . I have is CP5711 siemens , it is having USB cable from Laptop to CP5711 Port. but does not have a cable from Other side (serial)...
4,381
Does anyone have a pinout for a IDEC PFA-1A51 cable or know where I can get one? This is used for the FA-2Junior plc programming.🍻
5,769
As Forum users frequently request this kind of information, I thought it would be useful to post this link to a recent Article from the Rockwell...
2,944
We had been using the 1784-PCM/5 cable which connects our PCMK card to a 9-pin male connector. It also has an 9-pin to din adapter 1784-CP7 that...
5,953
