CAI WebControl
olech
Aug 2012
Norway
Hey
CAI WEBCONTROL
webControl™ has 8 digital inputs, 3 analog inputs(based on 10bit A/D converter, full scale 0-3V), up to 8 optional DS18B20/DS1822 based temperature sensors, one optional Honeywell HIH-4000 series humidity sensor, 20 custom definable timers to combine and define its 8 digital output in any sequence of those combined input.
im trying to figure out if its possible to use 100v-230v sensors for 12 volt PLC?
http://www.ebay.com/itm/White-Door-...752?pt=LH_DefaultDomain_0&hash=item2a20ed8260
The door contacts is 100v but my PLC's inputs is just 10 volt.
Is it possible to go around this in anyway? both way relay?
i live in norway, here we have 230v 50hz.
100v is the maximum voltage. It is a 2 wire magnetic reed switch so you can use your low voltage plc power to run through the reed switches and back to your input.
Hi, I have written a program for logging data from the WebControl PLC. The program is compiled in VB 6.0, and should run on all computers from...
2,895
