Calculate Average Flow Rate
Critt
Apr 2006
Ontario
153
I'm working on an application where I need to calculate the average incoming flow into a wet well cell for the past 30 mins by tracking the rate of level increase in the cell.
The wet well has ultra sonic level transducers so I know the level of the cell. Unfortunately I don't have flow meters on the incoming pipes.
Any help would be greatly appreciated.
Assuming the pump isn't running it is very simple. Volume is the change in height x plan area of the wet well. One cubic foot = 7.48 gallons. Flow rate = gallons/30minutes = gpm
If the pump is running and you have a flow meter on it then the flow rate is the algebraic sum of the pump flow rate and the change in level.
If you have two level switches turning the pump on and off then all you need is a timer. The change in volume divided by the time between pump off and pump on is the flow rate.
I have a sensor that detects the speed of conveyor belt, by counting a pulse. On the assembly line come bottles at regular intervals and which are...
3,601
Hi everyone. I'm relative inexperienced with plc's but very curious. I'm starting to use an s7-300 siemens plc, and I'm starting to program with...
14,214
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,044
Good morning, I have a question. I don't know much about ST yet I would like to calculate the average number of products per hour. how do I do...
22
2,973
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,110
