Calculate Speed
OBS! At 80 Hz you are far out in the field weakening area. The slip may be much bigger than calculated above.
Here is a link to Basic VFD theory.šŸ“š
Kalle
The reason I added the *disclaimer* ( if the drive is not doing anything tricky) at the bottom of my calculation is for this reason, just in case we started to enter some advanced motor control. If the motor is wound in the correct fashion it is a vaild approach to move the field weakening point, see the attached document.
Hello, I'm trying to understand a servo motion system. I want to know the motor speed in RPM at a given speed setpoint entered in a MAJ...
2,266
We like to know the speed of a vehicle, itā€˜s a normal car. Two photoelectric sensors (mounted only 1 meter distance from each other) are connected...
3,987
hi I want to calculate speed rotation (RPM) with Omron PLC using a optical or proximity sensor. Thank You in advance
9,588
Gear Reduction Box = 3.0 Drive Sprocket = 22 Teeth Driven Sprocket = 88 Teeth VFD = PowerFlex 40 I have a VFD controlling the speed of a...
25
29,665
Hi, I am looking for a little help. I currently have an old Telemecanique TSx 17 that I need to replace. I am looking at installing an AB...
2,511
