calculation help for digital to analog converter
and for the speed do i need to times 3500 to the 0.366211 value cause i was told by my instructer to do so..
your calculated value
0.366211 is (RPM/BIT)
lets check that first
0.366211 * 4096 = 1500 All good
so lets work out the mA for the RPM
16/1500 = 0.01066667 mA per RPM
so x 200 = 2.133 mA above zero
so add the ofset of 4mA
6.133mA
same values different approach
The most important thing with calculations is to include the Units.
NOTE :- 0.01066667 mA per RPM
so 1200 * 0.01066667 = 12.8 mA
your 3500 number was not RPM it was BITS
very important to use the correct units
normaly you would scale something once
but
16/4096 * 3500 = 13.671 mA
when I was learning to be an Electrician
we had two things drilled in to our small brains.
1. use the units always
2. show all stages of the formulae.
and
check the result with an approximate value
eg.
4096 = 1500 = ratio of 2.7 : 1
200 x 2.7 = 546 = about 1/3 of 1500
the value looks correct see
Hi!! I'm looking for Temperature rise calculation software from Rockwell, I just download "Product selection toolbox 2022" but this software is...
226
I have a machine that I am trying to modify to run like it's older twin. It's a sheet material coming into a center winder and we need the line...
1,929
I need help determining how to code a motor FLA reading. The HMI has a numeric display with a bar from 0-150% FLA and it's looking for a integer...
1,723
Hi all! I was looking for a little help in determining a better way of accomplishing a current process that is not to efficient with in my...
2,212
I am new to this forum and am hoping that someone can help me with what is most likely a very simple SCCR rating calculation. I have never...
7,444
