Calibrating a current temp input
Tonk
Oct 2005
Brit in Grand Haven
46
I am trying to calibrate an Siemens 13 bit analogue card to read a temperature can anybody help me on how to set the current input to be linear with respect to my temperature applied. Have tried several ways in my PLC but having no luck so far. Can track my temperature about 1/3 of my scale then my displayed temp to my actual measured temp using a fluke start to deviate.
I assume by the title that the analog input is a current input (ie 4-20mA). Is that correct?
If so, then what are you using as the temperature sensing element? Is it a thermocouple, RTD, thermistor, or other device?
If you are using a thermocouple connected through a tc to current converter, does the converter provide thermocouple linearization? Many converters do not linearize; the linearization must be done in the PLC. This can be a complex and CPU intensive operation - but it is something that I do from time to time.
Hi all, Probably a bit out of my depth here as I'm not an instro but just wondering if someone could provide some clarity on calibrating/scaling...
3,014
I know this is very far off subject, but was hoping someone here could lend a hand. I have been asked to start calibrating belt scales for...
19
3,781
I have a vacuum furnace running an Allen Bradley SLC 5/03 with a PV 550, I am new to PLC's and using RSLogix 500. My issue is that the control...
35
4,874
this is one of the assignment that i have been given in my training course, i really don't understand the way to do the calculation required for...
11,600
I am looking for information on the proper calibration of an 1756-IF8 analog input card, preferably the wiring of the voltage source. Rockwell...
8,034
