Calling FC-105/106 multiple times in Siemens Step7
aamirawan91
Feb 2024
Karachi
33
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff automatically. Anyway, I am trying to use the scaling functions from the step7 library "FC-105" for scaling and "FC-106" for unscaling. I have to call these functions multiple times as there are a lot of analog inputs to be scaled and a few analog outputs to be unscaled. I used/called the function FC-105 for the first time without any issues but as soon as i dragged and dropped it the second time it said "The object 'FC105' already exists. Do you want to overwrite it?". Now what should i do here? Should i rename it or overwrite it? How does selecting either effects the program?
Once you have dragged it from the library it will exist in your project so use the project blocks folder from then on.
I am looking to get an AB series 1774 (PLC1) from the 1970's up and running. I have all the parts, and it powers up just fine without errors if I...
2,333
Hello all, I’ve recently begun using Automation Studio on my own time to boost my knowledge of controllers beyond AB/Siemens. To ease myself into...
906
Hello I'm new to PLC programming and I'm programing in ST. Programming envirement is GX works 3. I can't figure out how to jump to subprogram or...
1,468
I have some code i need to block until a super genie for data entry has completed (by operator input)as per below. FUNCTION New_Setpoint()...
2,280
I have a display that I can't find out where it is being called by. is there a "Display tree" that shows where each display is being called by? I...
2,202
