Russ
I was at a customer's site today, and went to do some trending, and pid monitoring. When I went to go online with the processor I realized that the most recent version of the program wasn't compatible with what was on the processor.
I figured that a recent power outage might have caused the program to load from non-volatile memory, and the most recent edits might have been lost. They weren't critical to the operation, and I still had all of the edits saved, so I wasn't too concerned.
I compared what I uploaded with my most recent version of the program, and for the most part I noticed that the most recent modifications were gone.... no big deal....
However..... then I found this (rung 22)... (see attached jpg).
What could have caused this? Is it possible that a power outage could do this? I've never seen anything like it before, and am a bit concerned....
Thanks in advance...
This rung is part of a specialized automated control routine that was worked up specifically for this site. When doing the initial controls work, before the implementation of the automated portion of the code, a competing engineering company repeatedly downloaded the software, and took extensive photographs of the physical modifications - without permission from the OEM nor from the site.
The rung in the picture is a critical portion of the routine.
When I last left site, back in August, I realized I hadn't secured the processor using the CPU Security Tool. At the time, it seemed as if the attempts to steal the process had come to an end, and so I wasn't too concerned.
This routine allows a thermal oxidizer to remain operational throughout a wide variety of Air Liquide membrane and pressure configurations, at numerous bio-methane facilities. It automatically adjusts to the changing waste stream composition, allowing the plant to optimize production, without risk of inadvertent shut downs.
There has been remote access in the past, and it's possible that someone accessed the network remotely.
