Hello
I am new to the forum and new to PLC.
I am trying to program a simulation on LogixPRO but having no luck in figuring it out.
Heres what i am trying.
Each time a input is pressed the corresponding output is activated along with the one before and the one after in the line and then have them stay on for lets say 2mins befor going off.
But if the next input in the line is pressed befor the timer has ran out, then its corresponding output will active along with the next one in the line and the one befor and they will stay on for 2min.
Say i have 6 push Button inputs (I:0to I:5)and 6 LED output(O:0toO:5). if i push Lets say I:2 then O:1,O:2 and O:3 will come on for say 2mins befor going out but if i push I:3
when the timer is on 1min O:2, O:3 and O:4 come on for 2mins.
so from thereO:1 will still go out 1min befor the rest.
can this be done? and if so what is nthe best solution.
Thank you to any one that can Help.
Neil
Neil
