Can Bus
Bascially a can bus is one that permits the passengers to consume cans of beverage whilst onboard. Its most commonly used as a school bus as kids tend to drink cans of soda on the way to school. ;)
Hope this is off help
http://www.canopen.org/can/
In the US the term "can" is sometimes used as slang for the bathroom. In that case, I believe the "CAN bus" best describes the sewerage system of a city. Each home being a node and each toilet, urinal or bidet being an addressable point at the node. In this producer/consumer network, there are usually a multitude of producers and only one main consumer (the sewerage treatment facility). Occasionaly, during storms with heavy rains and flooding, the system becomes overloaded, the flow of data is reversed and the CAN bus is said to be full of sh**.
Actually the Can bus will always take you on a positive ride and the Can't bus is always a negative ride. (Sometimes grounded but usually un-grounded.)
A septic skeptic (or is that aseptic)
Eric Nelson said:
I think Google uses Norm's version of CAN Bus in their Tisp System... ;)
-Eric
You gotta be SHI**ING me.
When IF I get going on my electric vehicle project I will probably learn more about CANbus. Right now my only knowledge is that it is used to have vehicle components "talk with each other"
Dan Bentler
Francie Bellew said:
Would it be fair to say that a field bus is a vehicle that can be used in a field?
Something like this you mean ?
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
117
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
227
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
168
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
