CAN I USE SIEMENS CPU212 to control Mitsubiishi Servo
MR-J2-B is an SSCNET servo. Nobody but Mitsubishi offers SSCNET. You need to use it with an older Mitsubishi motion controller.
If it was an MR-J2-A it would be a standard pulse train, and it could connect to any controller capable of a high speed pulse output.
Either way, MR-J2-B is obsolete, replaced by MR-J2S-B, and now by MR-J3-B.
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
161
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
84
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
152
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
184
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
182
