CANBUS Question
richleva
Sep 2012
ontario
79
Does anyone know if Canbus communication will work using standard SOOW Cable at about 50 feet ?
does it need to be a shielded twisted pair?
We have long hole drills underground that are remotely operated via Canbus, and these cables get destroyed within week/months. the manufacture wants 4000$ for a 50' cable?
In the OEM cable there is a Canbus cable for PLC communication and 8C #16 for power, estop, tilt switch. So two cables in one wire loom.
Just wondering if the separate Canbus cable is required for only 50 feet of cable?
Try it and see, but don't be surprised if it is unreliable.
In general, CANBus needs a balanced pair with about 120 ohm characteristic impedance. Twisted pairs are usually used in round cables, and parallel pairs in flat cables.
Lots of folks regularly run nonstandard cables, or omit the necessary termination resistors, for short CANbus links. But when they have trouble, the first thing out of the manufacturer's mouth is (correcly): "put in the proper cable and call back when you're done".
Hello everyone! I have a Schneider M241 as master of a CAN network with several encoders and whatnot, everything is working fairly well. Now...
1,718
I've wanted to experiment with this for a while, and this morning was the perfect time with the cold, heavy rain. I have a 1756-DNB in my test...
2,711
Hello, I am fairly new to PLC programming and i have a problem connecting two devices. Mainly my problem is how to read data from the RFID which...
2,471
Does anyone have any implemented example code for using a SDOR/SDOW in a Proface LT4000? I am wanting to read and write the control and status...
2,560
I need to design a machine, it will have 5-6 servo motors and around 40 sensors. I am now going to choose how to connect the whole machine. I...
2,227
