Cannot Create v6.1 .mer With FTView V6.1??
Peters64
May 2014
MA
Hi Everyone,
I have recently converted a PanelBuilder32 file to a FactoryTalk View ME v6.1 development environment. All is well except when I go to create the .mer I only have the option to create v5.1 and lower runtime files. I would like the runtime to be v6.1 to match another HMI on the system. Is there something obvious I am missing here that would inhibit this? Any help would be appreciated.
Thanks!
Is it a model with DeviceNet or Remote I/O ? Or maybe a PV+400/600 ?
When FactoryTalk View Studio 6.10 came out, some specific models of PV+ weren't available with v6 logic modules, so it will only allow you to make Runtime files for older firmware.
I will be putting the runtime on a PV+ 6 600. Would I simply just have to change the project from referencing that PV+ in the project settings?
Wow. So I just tried it and if I go into Project Settings and change the project window size from PV+ 400/600 to Custom 320X240 it works...
I didn't know that changing it from "PV+ 400/600" to the custom resolution that happens to be the same as the PV+ 400/600 would work. Thank you for posting that followup.
Hello, I am having an issue trying to open or create new projects which have L8 CPUs inside. I have tried with several versions of Studio5000...
1,499
Hello all. Hoping someone could give me a lead to follow. I'm currently using Factory Talk v13, however it will not allow me to access the...
1,344
I'm trying to use Studio 5000 Logix Emulator. Whenever I click Slot > Create Module, I receive the following error message. >Cannot create module...
2,914
I'm a student going through an FMS training course and currently trying to upload a RunTime application (a pre-made example file that teaches you...
2,464
I ran into an issue with an application that I think would be useful to share for anyone that experiences this problem. The problematic...
1,340
