Cannot open WinCC Project V6 help
Nov 2018
Melbourne
Hi, Im trying to open an old old Siemens WinCC project.
It doesnt have to run i just want to look at the project in WinCC explorer.
Its quite a large project and heavily configured with many terminals
When i go to load the project it says it cant find the configured server naturally is not available and asks if i want to open the project using the local computer as a server. I select yes.
It then dumps the following.
Cannot open WinCC Project - Project Manager for the configured server is not running. Check the computer name of the server.
Ive tried alot of different forums and checks. I just want to look at the project to see what the old project looked like to create a new one on a different platform.
Any ideas how to solve this??
Does it name the server it's looking for that it can't find? If so and you have a PC you won't frag factory talk on etc. you can rename your PC to that and it should work. Or at least with factory talk if you rename your PC your projects have to be relinked with Windows user account management.
I renamed my computer to this.
But maybe i didnt name it correctly
I can look at the corresponding step 7 classic file.
I called the compute the name of the OS system in the main directory tree
Is there another way to check this
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
344
Hello, I am having an issue trying to open or create new projects which have L8 CPUs inside. I have tried with several versions of Studio5000...
1,467
Hi all, I am having this strange issue with FT view SE where it won't allow me to open the project. I've attached the error for reference. It...
3,267
I have a couple PVA files that I am unable to open. I have tried re-installing PB32. I have used versions 2.6 and 3.83. Want to see if anyone else...
1,164
Hi, I have a setup (first for me) with a Micrologix 1400, PanelView Plus 7 and a Yaskawa A1000 drive. Everything was working fine on Friday...
2,319
