Cannot Set IP Of CompactLogix
samir13k
Jun 2018
Huntington, IN
Hello all,
I'm hoping this will be something simple, but i've been fighting it for the past 2 hours.
I have an L16ER-BB1B processor that I am trying to set the IP on.
When I use BootP, I cannot disable BootP (tried well over a dozen times, clicked the button multiple times, power cycled, etc).
When I hook up via USB, I can see the processor in RSLinx and I can download a program to it. When I drill down the tree in RSLinx, the IP shows 0.0.0.0
When I right click on the Ethernet node and select module configuration, I get an "Unable to communicate with the selected module" error.
When I right click on the "PLC Rack" and select module configuration and go over to the port configuration tab, I get an "Unable to read the modules port configuration" error.
When I go in Studio 5000 and go to the internet protocol tab, it is completely grayed out, whether I am online, offline, in run mode, or in program mode.
I'm out of ideas, any assistance would be greatly appreciated.
Regards,
Samir Shaikh
Try using the USB to set the IP.
To clarify, connect via USB, then in RSLinx, right click on the node, and select "Module Configuration". You set the IP in the Port Configuration tab there.
The Rockwell DHCP/Bootp applet has been mostly broken mostly forever. Other setters work, like the one from PLCTools.com, but the Rockwell applet is just a broken mess.
Hello all,
On the Bootp app: go to Tools, then select Disable. This works for me when the button doesn't work.
There's a known issue with the latest version of the rockwell BOOTP utility. Basically they forgot to actually attach any code to the disable BOOTP button. Tools>Disable or right click>disable works. There are several other things that might interfere with this process, none of them related to the software, but that button will definitely not do the job.
Technote 948444 (TechConnect Required) details this issue.
(I think I've said it before, but I can't decide which fact I find more idiotic - that the issue has been unfixed for two years so far, or that Rockwell decided that this issue is a tech-connect contract only issue)
Hi everybody, I have this variable (Activate1) that should be set when I activate a button from the hmi, but instead is only set as long as the...
1,255
I have a fair amount of Logix and Studio experience, but this is my first project with Studio v33 and a 5069 CPU and -IY4 card. The processor is...
1,159
Hi folks, so... firstly I have setup a hydraulic pressure test system. The system is used to pump up a volume to a set pressure - i.e. if we need...
3,352
I have a graphic that has 2 buttons for Automatic and Manual, each with pushbutton animations associated with them to toggle a bit in the PLC, one...
2,536
Hi guys, I am trying to connect AB compactlogix 1769-L30ER through Ethernet cable to my laptop. I use Rslinx version 3.9 When I enter IP address...
3,562
