Can't go online with 1756-L73S after L5K export
steveb1475
Oct 2005
Utah
111
Hey all,
Having an issue with a 1756-L73 (v20) where I'm getting a fatal error when trying to save the program online *only when selecting yes on upload tag values*.
Spent about an hour on the phone with tech support. Apparently something is corrupt in the processor and ofline program according to the tech. He recommended doing an l5k export and import with another copy of the program.
Problem is that after the l5k export and import, the only option is to download when trying to go online. I noticed that the program before the l5k is safety locked and after the l5k import the program is not safety locked.
Is this the reason that I only get a download option? I don't have the safety password and I don't think that the manufacturer is going to cough it up.
Thanks,
Steve
Does not look good
Can you upload from the Processor?
If so
  • First is to make many backups - Backup the original program, The Uploaded Program, and your Offline Version that will not go online
  • The Aim is to find the changes between the offline program and the online program, make changes to the offline program until it can go online.
  • Run Compare (in Tools on the install CD I think plus else where)
  • Keep on changing the offline version until it goes online
An alternate method is to upload and then merge the comments (horrible way to go) from the Offline program with the uploaded program. Look at doing it in L5K format as there may be faster ways to do it
Others may know better ways
Guess I should have mentioned that a clean upload from the processor to a new file results in fatal error as well. I have many backups, I use AssetCentre. The problem is that there is something corrupted in the processor.
What I'm really wondering is what is the reason that I can't go online with the file after the l5k export/import, is it because of the safety lock password is stripped out during the export/import process?
Yes, and I can upload tags with the upload/download tool. Just fatal errors during save with upload tag values in rslgx5k.
Sorry you are now beyond my knowledge
Only thing that I know about L5K is to do with fiddling the Control net signatures so that when you download a new program the CNT card does not require re-scheduling
There may be something similar with the Safety signature but I do not know and I would not expect it (summat to do with safety, heh heh)
Your manufacturer should be able to perform the download remotely for you if they do not want to give out the safety password eg look at teamviewer and a Data card on a laptop.
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,936
Good Evening , I have a 1756-IF16 Analog Input card already installed in a working ControlLogix Rack. I need to add another Analog 4-20 ma...
2,180
Hi all, We have a machine with a 1756-L61S/1756-LSP processor. The programme is stored on a compact flash card inserted inside the L61S. The...
3,666
Hello Everyone, I frequently visit the site for great info, but this is my first time posting here. I apologize in advance for any newbie...
1,944
Hello! I need your assistance with the following issue. I need to upload project from 1756-L63 (v19.11) B Series controller for further diagnosis...
7,849
