Cascade control with Ratio control in RXlogix
sfk
Sep 2020
Edmonton
Hi
I have a scenario where I am controlling ratio of an additive into a uncontrolled Product stream to achieve a certain reading in a pressure analyzer which samples the mixture every 15 minutes or so. Currently the operator changes the ratio SP in a PID loop every 15 minutes when the analyzer spits out a value.
I want to automate this by creating a slow master loop with PV from the analyzer and use PIDE options to act on PV changes only. I want to set the output range of the master PIDE as 0-10% ratio values and feed it to the slave PIDE. I dont know if I can do that as the slave PIDE SPCascade is connected to the flow pv of addative. Can i connect the output of master to RatioProg of slave PIDE ? would the master slave config will work properly?
I am looking for an example of cascade control with level as the master and floe as the slaver. I am using RSLogix500.
1,642
Hey guys, After spending most of a day Googling looking for the answer, I finally decided to make a thread and ask the experts. I'm trying to...
3,576
RS5000 vs.20, 1769-L35E Processor, I have had an issue that I have seemed to work out between all of the PID posts I could find here and listening...
5,387
Dear all I would like to ask you for help in solving one algorithm, because I never worked with cascade PID. I have to realize heating valve...
8,340
I ask you answer if you know precisely what PID loop update time in a Rockwell processor is and if you are experienced with cascade loops. Thank...
5,775
