Cascading ONS and OSR instruction
ettikudiappan
Apr 2002
Singapore
131
Hi
I have an application where I have cascaded a ONS instruction and a OSR instruction. The ONS instruction preceeds OSR instruction. Is it advisable to do so? Do you foresee any problem when using instructions in this fashion.
if you don't use ONS-memory any more after this rung, You can
use -( )- as well, but this case it happends on same program scan.
In your model it heppends on next program scan when (OSR) conditions Rising. Anyhow it seems usable.
I don't understand why you want or need both.
I:0/0 B3/0 B3/1
--] [----]ons[--------------( )----
equals one shot rising edge.
I:0/0 B3/2 B3/3
--]/[----]ons[--------------( )----
equals one shot trailing edge
Use B3/1 and B3/3 as "one shot" bits for I:0/0 throughout your program. Or in your case U1_gripper_clear input.
In your code, because of the ons after the gripper_clear input, the result of the rung--even if it's a normal B/* coil, is only on for one program scan. The OSR at the end is a waste of a bit. Now if you need to examine the gripper_clear later as a one-shot, you'll waste another bit on another one-shot--plus you have to fat-finger more code.
What I do normally, is figure out which of my inputs I will need as one-shots--anywhere--then do them as I did above. Then I've got a "one shotted" bit to use over and over again.
Oh sure, NOW you give a picture... :rolleyes:
See my initial response in the OTHER THREAD
With the addition of the picture, it becomes more clear. In the OTHER THREAD, I was picturing this:
|---] [-----[ONS]-----[OSR]
With the ONS immediately preceeding the ONS, and therefore my response was wrong.
In THIS thread, the ONS creates a 1-shot for the "U1 GRIPPER CLEAR" switch, while the OSR creates a 1-shot for the output. From what I see, the OSR can be safely replaced with an OTE, but the ONS CANNOT be removed (or moved).
Again, The purpose of the ONS is to look for the leading edge of the "U1 GRIPPER CLEAR" switch!... (n)
beerchug
-Eric
Hi I have an application where I have cascaded a ONS instruction and a OSR instruction. The ONS instruction preceeds OSR instruction. Is it...
8,174
Good Evening , I have a Conveyor system that requires Speed Cascading from one conveyor to another. Meaning that if one conveyor speed is...
2,601
Happy Holidays Folks! I am working on a robot cell and as we are adding PLC control to the system, I have some questions about implementing an...
4,758
I'm new to PLC. Have little knowledge of VFDs. I've 5 nos of Delta M series VFDs and all are connected to motors running the conveyor belts...
2,862
Hello. I am a student doing an independent study on PLCs. I am using a Allen Bradley SLC 5/02. What I am trying to accomplish is to step a simple...
4,238
