CC-Link
Oct 2004
51
I am trying to set-up CC-Link for the first time. I have never done this before and I am new to PLC development, so any help would be appreciated.
I only have one board in a module, and im only setting up one station.
I would like to set the following up as printed.
Remote Input (RX) = B0
Remote Output (RY) = B500
But when I do this I get this error, "The range set for the refresh device is not right". What does this mean?
Could anyone suggest a remote address range for me to set. Im slightly confused you see.
Ok. We have a main panel with real I/O. Do I just work around these addresses?
Also when I do this and then check the IO I get directed to a 'Checking MNet' screen. What is this?
Gareth not sure about MNet, but yes just avoid exising X and Y addresses. I would leave space in case you need to add to existing rack. you can also specify D Registers for remote registers RWr & RWw. Its not easy working out which module they relate to, there is a lookup table in the manual.
Check your private messages and I can email some code with an example of the setup
Good afternoon, I have a problem communicating with a system, I will explain it briefly. I have a HIS -ML17- CTBH monitor connected to an...
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
116
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
95
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
104
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
362
