CC-link
euuil
Mar 2004
Hi guys,
I'm now facing problem with Mitsubishi CC-link remote I/o.
There is 1 master & 2 remote i/o (input & output). From master I can receive input signal, and I also can send output, but there is no output is turn on in remote module. All parameter and indicator are normal.
Please advice. Thank's for your attention.
how can you be sure that all parameters are normal?
what are the parameters? what are the node addresses?
do you get RUNL led on output slave?
are you sure you are turning right outputs?
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
110
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
86
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
99
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
351
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
116
