CCW Micro820 Questions
toddp65
Aug 2014
Florence, Ky
282
While creating a project, I've discovered an issue trying to utilize related instructions from others in different programs. It seems as if if you use and OTE called Level switch On and then try to use the same address for and XIC in another program (routine) in the main program, it doesn't seem to correlate.
The OTE is in an input mapping program and the XIC is another control program. There doesn't seem to be an calls or JSR so it appears as if all of my routines are active. I couldn't just copy and past or drag and drop that address from the OTE to the XIC, doesn't seem possible.
Does all associated code need to take place in the same program (routine).??
If your program is put together by using smaller programs and you want a variable to be visible to all programs they will have to be "GLOBAL", otherwise, they are only available to the local program.
I figured as much, I thought when I created those particular tags they were global. When I made one single program with all the tags vice multiple they obviously worked. This is experimental so when I redo the program I’ll ensure they’re global.
Just so you are aware, all you have to do is "CUT and PASTE"!
Cut the tag from the local and paste it to the global.
Just make sure you "CUT" because if you copy - it will be the local tag that gets updated!
I just discovered in order to avoid that mess would be to initially create the tag, no matter what program, changing the scope to user global variables. Seems like by default it choses local scope.
hey guys, so I've been stuck for a couple of days trying to connect to a Micro820 version 12 using CCW version 12. I see the IP using "Discover"...
1,665
Hi, I started my journey with Micro820 and I have to read input status address 10001-10010 from one device via Modbus TCP, everything works fine...
1,193
Hello all. Is there an easy way to perform a compare for 2 versions of a Micro820 program in CCW?
1,281
Can anyone tell me how to make an array, say a DINT [16] in CCW for a Micro820? The tag editor seems to be forcing me to make a tag for each...
5,845
