Ccw power flex cable
bright676
Nov 2012
va
494
I have the A/B CCW and would like to download all the inverter settings in the plant.
In the manual it says to use a 1203-USB cable. I never hear of this cable but it looks like a 1747-UIC cable I have. A/B wants almost $400.00 for one.
Does any one have another way around this 1203-usb cable that A/B says to use?
Well there is the 1203-SSS, this one uses serial.
Are these drives networked or are they all stand alone?
AB drives talk DSI or DPI and the only way apart from the networked drives is to use a 1203.
The advantage of getting the 1203-USB is that it comes with 2 cables one to talk to the PF7 and the 1336 drives and one cable to talk to the PF4 drives.
The PF4 drives use a RJ45 plug, whereas all the other drives use a miniDin plug.
Alan.
Hi All, Hoping the community here can help as I'm new to PLC programming. The project I'm working on is using a Micro850 2080-LC50-24QBB and...
1,707
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
38
434
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
105
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
273
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
188
