Checking DC Resistance of a Transformer
I was told this machine caught fire about a year ago around the transformer when the whole plant electrical system single phased. They since put in a phase balance detector that will kill the main power to the machine.
I don't see how a 3 phase transformer with a delta primary would go bad or catch fire only from single phasing. All this makes me suspicious that it has the wrong transformer.
I expect to be back at this plant this week and intend to do a little more investigating.
Is this a European machine 400V/50Hz?
Instead of 480Delta to 400Y, I have had much better result with 480D - 380Y transformer.
Yes, it was built in Austria about 15 years ago. The main reason for the transformer is because the mold heaters were designed for the voltage in Europe.
Hey Everyone! I need to pick your brains and see if we can come up with a solution. I am working on a PLC Project where we are pumping acetone...
5,273
Hello, can someone share/explain How to check comms between PC and PLC via TeamViewer? TIA
390
Hello, I have a question on an OCR application I am doing. I am reading in 16 characters that come from a camera into the plc in its input words...
1,278
I have some questions about MSG Type checking Does a MSG instruction care if the name of the UDT type are different on each PLC as long as...
3,461
I just finished making my 3rd service call to a large machine shop, troubleshooting PLC issues. I can see that none of the PLC or HMI programs are...
3,054
