Cimplicity, Kepware and SLC 5/05
prabhjeet
Jun 2008
Bristol
Hello friends!
I am working on a project where I am considering using KepServerEx instead of RSLinx Classic to be the interface between SLC 5/05 controllers and Cimplicity.
Cimplicity manual doesn't speak of KepServerEx anywhere (it speaks only about RSLinx). I am fairly optimistic that someone, somewhere has implemented this - or at least has a good idea as to how to achieve this.
I am looking for help on this - first question being if it is achievable. And the next - if yes, how.
In the meantime, I will also be spending some time on it and in case I get some results, I will post these.
Thanks folks!
Cheers
There is absolutely no problem using Cimplicity with Kepware. We have it like that in a lot of projects.
You just need to check how is the driver for the SLC 5/05 is working
What you're looking at is using KepServer Ex as your "OPC Server" (Cimplicity being the "OPC Client"). You can download a free trial version of Kepserver Ex from Kepware's web site. Also that's right in their lane, if you have problems or questions, contact Kepware directly - they tend to be very helpful.
Thank you guys for your time. I could make Cimplicity talk to SLC 5/05 using Kepware.
Like you suggested, I configured the Kepware to be the OPC server and Cimplicity as OPC client.
The test application is working fine with 2 SLC 5/05s on the ethernet. The port number had me guessing for a while but, in the end, leaving it to default value of 2222 worked.
Many thanks again.
Good times - no problem. I think you'll also find that KepServer outperforms RSLinx in addition to being priced more reasonably. IMO, the only downside is the lack of "browsing" ability that RSLinx supports.
Many thanks again.
Dear all, It's my first time configuring the cimplicity taking values from a remote Kepware OPC server on a Windows Server 2012 station. I have...
4,831
Hi All I'm trying to test Cimplicity with Kepware both Demo and latest version. both are on the same machine.connecting to GE 9030 cpu 374...
5,323
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
23
200
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
197
