CIP Connection to Micrologix 1500
I will be using a serial to ethernet connection port.
If this is the case, how many CIP connections can the Micrologix controller handle ?
You will be using an Ethernet to Serial converter. The serial port, last I checked can handle a baud rate of up to 38.4k.
It depends on which device you chose how many CIP connections the interfacing device can use. Tell us more please.
The very common 1761-NET-ENI from Allen-Bradley can support six TCP connections; two outgoing, two incoming, and two either way.
I've never examined whether those TCP connections are also 1:1 with a CIP connection, or if the Net-ENI is always using Unconnected messaging.
In practice, I limit my Net-ENI connections to one HMI and one programming terminal. These devices are notorious for their low TCP connection capacity, and it's easy to accidentally use up TCP connections with RSLinx browsing or other diagnostic functions on the network.
Hello Experts, I would like to ask a general question and just wondering if someone can help me to explain it. So I have a AB Compact logix...
5,599
Environment: MMI Side: Intouch 10, ABCIP.5 connects with one 1756-L71; ABTCP.1 connect with few PLC5 1785-40E PLC side : 1756-L71 5570 Controller...
2,353
We have a small ring network of point IO racks all using the 1734-AENTR communications adapter. These all are connected to a 1769-L33ER...
2,980
Guys, Would you please let me know what the meaning of CIP connection is? For instance, when we say a controller has x amount of CIP connections...
10,166
Hey folks, Just yesterday I upgraded and old L1 processor and its ENBT module with a new L71 20.015 and EN2T 10.00?. The L1 was used for nothing...
4,878
