CIP Data Table Write
fifty60
May 2017
Kentucky
Hello everyone. I have a compactlogix L24ER PLC that I am trying to use to send data to a windows 10 PC. It works, but I want to understand why it works.
The PLC is using a MSG command to send a CIP Data Table Write message tot he windows PC. The path of the MSG command is what is confusing me. The path is 2, 10.10.225.32, 1, 0. The PLC is on a 192.168.1.20 IP address.
So the PC's address must be 10.10.225.32, right? But it is not, and it still communicates to it. Am I not understanding something about this command? The Path in the MSG command must be the PC's IP address, right?
Also, your PC can have more than one IP address assigned to it. Do an IPConfig command from a Command Prompt and verify all IP addresses assigned to that PC.
Is the PC running a virtual machine? The Virtual Machine could hav eit's own separate IP address assigned to it.
Do you know what device is at that IP address?
OG
Normally, one would have software on the PC that reads from the PLC rather than the PLC messaging the PC.
What software is receiving the data?
I'm having trouble writing data from a CompactLogix PLC to a ControlLogix PLC. My CompactLogix (IP 192.1.5.70) configuration : Mu...
3,084
Hello forum members. I was hoping if you guys can help me understand why this CIP instruction is error out with this code 16#000C.
1,468
Hi everybody I wish you could help me with this: I have 4 CIP Data table read messages and 1 CIP Data table write message that communicates from a...
3,931
Hi folks, I'm very much a newcomer to PLCs in general and the CIP standard in particular and have a problem I hope someone could shed some...
7,566
I'm having trouble reading data from a ControlLogix PLC to a CompactLogix PLC. (Adding the I/O and using produced/consumed tags is not an option)...
27,686
