CIP Message to ILX56-PBM
jowett34
Apr 2011
England
Hello forum! Long time user, first time poster.
I am currently designing a control system that has a Production system, linked to live plant equipment. There are 4 PLCs in total. Most of this I/O will be connected via Profibus using ILX56-PBM cards in the local rack.
Alongside this Production system will be a Development system which uses IDENTICAL software to the 4 Production system PLCs, with an extra Simulation PLC. The Development PLCs will NOT have the ILX56-PBM cards in the rack, but as it's a copy of the Production system code, they will exist in the project.
What I need to do is be able to transmit data from the Simulation PLC via a tag or the same data type to the 4 Development PLCs straight to the ILX56-PBM module, as though the data were coming from the field.
I cannot change any software in the Development PLCs to accomodate this, so things such as Produce/Consume are out of the question.
I've been trying to use a MSG instruction in the Simulation PLC to "CIP Data Table Write" . I've tried making a Source Element type with the same data structure as the one in the local rack with the Destination Element as the card in the destination rack, but I get an error code 16#000f - Access permission denied for requested service. I guess it's something to do with differing data types in the structure it's not happy with.
All I need to be able to do is write to the PB_Input_x within the structure PS:ILX56_PBM:I1:0. I can do this one-to-one with a message for each iteration of PB_Input_x, but there are over 400 of these, multiplied by around 4 ILX56-PBM cards per rack, that is a lot of messages.
Is there a way to offset the element number, maybe using an index array and just send the data I need?
Help much appreciated, thanks!
Wizards, It has been a few, but you all have always done me well. I have acquired a 1769-L33ER and want to use it as my collection PLC to...
520
Hello, PLCS.net guys. I'm learning about MSG for TCP communication recently. I'm trying to use CIP Generic. And the main flow is like the one...
1,238
What's the easiest way to monitor a CIP data table read or write instruction. I'm reading and writing from a Compact logix to a micro 820, over...
1,500
MicroLogix 1400 Using Messages to talk to PowerFlex 40P 22E-Comm Card. I have it working and when I download an updated Program (nothing in the...
2,378
I would like to Read the CPU Usage % information like the Task Monitor tool provides from one ControlLogix to another via a CIP Message. Comms...
5,908
