Citect device groups
LCHF
Nov 2019
Sydney
I am currently logging alarms to a single device without issues and I am trying to configure my alarms to log to two devices but I am running into problems.
Steps I have tried.
  1. Created a second device with name "AlarmSQLDatabase". Original device is called "AlarmDatabase"
  2. Created a group called "AlarmGroup" with association 1 = "AlarmDatabase", association 2 = "AlarmSQLDatabase"
  3. In alarm categories I updated "Log Device" from "AlarmDatabase" to "AlarmGroup" (I had to type this manually as it was not in drop down list).
When I try running it I get "Group not found" error message.
I am running Citect version 5.42
Am I doing something wrong?
Your process is exactly correct.
I think i know what the issue is, can you change the device name "AlarmSQLDatabase" to "AlarmSQLDatabas" in both device and group forms, then pack and compile to see if that fixes it.
No problems, makes it easier to help when you have explained so well what you have done. In case you haven't guessed there is a 15 character limit on device names in the old version of Citect that your running.
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
389
How to check the communication between the Micrologix1200 to Citect SCADA. I use PLX51-DF1-ENI router to communicate in scada. I tried to use...
1,350
Hi Guys, Hope someone can help with this. I am trying to log variable changes to a text file using the Log device in citect Scada 7.4x My Log...
3,913
Hello i want to append a record to a text format device of Citect, but seems that it overwrite the record every time when open the device, i...
1,273
I have my HMI PC running on vijeo citect. Now I have connected an ethernet switch which is connected to the PLC. To access the plc using OPC...
1,179
