Citect multi monitor
eddolls
Dec 2015
England
im running citect 2016 with 4 monitors. i have used the multimonitors paramiter in the config.ini file and set to 4 but for some reason it only uses 3. is it something to do with me using the tab_Style include?
Check the monitor numbering in Windows, and make sure they are numbered 1-4 and not something like 1,2,3,5. I find the monitor numbering in Windows not to be reliable, and the numbers can change. My end user decided to arrange the windows on each of the monitors himself instead of me trying to assign each screen to a monitor.
This is my setup:
Under Multimonitors:
Monitors = 3
ScreenWidth=1024
StartupPage1 = Display1
StartupPage2 = Display2
StartupPage3 = Display3
Make sure that the screen resolutions of your monitors are the same, and that the screenwidth parameter matches them too.
I do mean citect.ini sorry I've been dealing with a lot files recently.
3 screen's work fine it's the 4th screen that doesn't work however I haven't tried specifying a resolution I will try that next
Hi, I'm new to citect scada and need help setting up multi monitors. Really need to be walked through it. thanks
1,871
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
29
67
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
97
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
76
