Citect Scada Trend inside Genie using metadata
Walls
Mar 2019
Åros
I'm fairly new to Citect Scada and am currently working on a little fun project that goes alone nicely with my PLC program.
When I have a frequency converter connected I normally send 3 analog variables, speed, current and torque, to the control system. In my faceplate I would like to show these, as I have set up the trendtags as part of the Equipment editor.
I've made myself a Genie, and have the Equipment set as metadata, and this is as much as I would like to transmitt, since the rest of the tag is already set in stone from the equipment editor.
However, I cannot seem to load the 3 tags using metadata names, such as "?Equip?.trendtag" or by using ProcessAnalystPopup function, setpens, or ProcessAnalystLoadFile. If I choose the trends in advance it works fine, but this requires manual work for every single time I plan on using this. Not really desirable.
This is the closest thing to working I've managed: ProcessAnalystSetPen(0,"?Equip?._Status_Speed_Trend","AN4"). This creates a pen in the requested window, but I get a cluster error, but that disapears after a few seconds.
Any clues what I might be doing wrong?
47
1. For how long period the trend shall be kept in history to be displayed on graph? 2. How to increase the trend graph history to be displayed for...
5,634
I have many sites using Citect SCADA version 5.5 They now have a management requirement to store process data offline. They will now copy the...
11,878
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
293
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
364
